Terminator 2 sound question
Question from Rich: Hello. I have a Terminator 2 arcade game that I have a question about. As soon as you power the game on, there is a steady humming/staticky sound that is loud enough to be a nuisance. It does not get louder or quieter if you adjust the volume of the game. All the game sounds work fine, it is just really annoying and constant. You can’t hear while you are playing a game because the music is drowns it out. Do you have any suggestions how to fix this? Thank you, Rich
Jonathan Leung Jonathan Leung ⋅ Staff March 20, 2015
Response from Jonathan: Rich,
We have selected your question as the Question Of The Week for this week. Please listen to the podcast at the link below to hear our thoughts on your issue. Of course, feel free to email us back if you have any questions about what was discussed.
Question Of The Week – Episode 53:
http://www.spreaker.com/user/arcaderepairtips/question-of-the-week-episode-53
Thank you for your question and good luck with your repair.
