Teamplay arcade Centipede Millipede Missile command
Question from Martin: Hi, I’m trying to restore the large version of this arcade cabinet and I am not able to find the right side art with the Missile Command image. Do you know a website or a place I can order this? Regards, Martin
Response from Jonathan: Martin,
I know that Team Play is still in business. You might try contacting them via their website (http://www.teamplayinc.net/) to see if they have any more in stock. You could also try contacting their distributor in your area (http://www.teamplayinc.net/distributors.html) to see if they have some as well. Other than that, it might be pretty difficult to get a hold of it. Hope that helps.
