Super Pacman Cocktail Cabinet Video Issue
Question from Greg: I recently picked up a Super Pac-Man cocktail cabinet that is having video issues. I’ve watched several of your videos but not sure what specifically is going on. You can see from the attached image that the screen is half blank and shifted. I have just ordered a cap kit, but wanted to see if you might have a suggestion on what specifically I might be dealing with. Thanks, Greg
Greg,
It looks like your monitor is experiencing some vertical collapse. Check out our post on Repairing Monitor Collapse Issues for more information. This problem is usually caused by an issue in the vertical section of your monitor. Specifically the caps in this section along with the vertical IC. Hope that helps.
