Purchasing A Cocktail Cabinet
Hi. I am looking to purchase a cocktail cabinet arcade machine, but I’m not sure where to buy it from. There is so many different vendors. My question is – can I just verify each one with their model number? If the model number is the same then the cocktail cabinet is pretty much the same right? I would greatly appreciate it if you can respond and let me know. Thank You, Hugh
Jonathan Leung Jonathan Leung ⋅ Staff July 10, 2014
Response from Jonathan: Hugh,
I can understand your confusion about cocktail arcade cabinets. As you mentioned, there are several different vendors who sell these cabinets and it can be difficult to determine exactly what kind of cocktail cabinet you are getting for the price you are paying. Unfortunately there is not really a universal model numbering system for arcade cabinets. Every manufacturer has a different model number and serial number system which makes it even more difficult to identify which cabinet is which.
With that said, you are more than welcome to send us some links to the cocktail cabinets you are interested in and we’ll take a look at them to see if they meet the criteria that you want in a cocktail cabinet. Of course, we would also be happy to answer any general questions you might have about purchasing one as well.
Hope that helps. Thank you for your question and good luck with your cocktail machine purchase.
