Pro Striker Replacement Bowling Balls
Question from Jordan: Hoping you can help me. I need some bowling balls for a Pro Striker bowling machine. The company who made it is no longer in business. Would you know where I could get some? It’s made by “Design Plus Industries.” Many thanks, Jordan
Jonathan Leung Jonathan Leung ⋅ Staff February 6, 2019
Response from Jonathan: Jordan,
The information about the game that we found on this site says it uses 2 4″ bowling balls. Suzo/Happ sells 4″ bowling balls for similar coin-op bowling games such as LAI Super Strike. Here’s a link to one such ball: https://na.suzohapp.com/products/redemption/HP2861. While we’re not 100% sure this ball will work with your game, there’s probably a pretty good chance considering it’s the same size and is used in similar games. We recommend calling Suzo/Happ before you order to see if they know about the compatibility of this ball with your game. Hope that helps.
