Neo Geo audio problem
Question from Joseph: Hey, my name is Joseph. I was wondering if I can get tips on how to restore audio on a Neo Geo 4 slot. It has sound but it’s too low. I can barely hear it. Please get back to me asap please.
Response from Jonathan: Joseph,
It’s pretty common for the caps in the audio section of Neo Geo boards to go bad. You might try Installing A Cap Kit on the board to see if it solves your issue. Our friend Raymond at Arcade Components carries these cap kits and also has a guide to go along with them that should help you out.
