Ms. Pac Man Question
Question from Jennifer: Hello, I have a Ms. Pac Man upright game. The game works fine except for the characters are squares instead of being ghosts and Ms. Pac Man character. How do I fix that? Jennifer
Jonathan Leung Jonathan Leung ⋅ Staff May 23, 2016
Response from Jonathan: Jennifer,
It sounds like you are having an issue with your Ms. Pac Man board. You might start off by checking out our post on Inspecting An Arcade Board for some helpful tips on troubleshooting board issues. After doing some research, it seems like this issue is usually caused by a bad chip in the 5F location on the board. You might try replacing it to see if it solves your issue. We also highly recommend checking out Lawnmowerman‘s Pac Man Page for some great information on Pac Man and Ms. Pac Man board troubleshooting that should help you out with your repair as well.
