Golden Tee 99 volume problem
Question from Geoff: I have a question. The volume on my Golden Tee 99 is stuck on highest level and I cannot find any way to turn it down. The trackball volume control is set on low but sound is full blast. Thanks.
Response from Jonathan: Geoff,
Check out pages 13-14 of the manual (http://www.crazykong.com/manuals/GoldenTee99.man.pdf). You’ll notice that there’s a volume adjustment setting in the test menu. This should allow you to turn down the volume on the machine. Please let us know if you have any issues with this and we’ll try to help you out further. Hope that helps.
