General Question
Question from Charles: Hello, I am hoping to find out some information about adding games to a pre existing arcade game I own. It is a Street fighter 2 unit. Would I be able to add more games to the memory? If so, is this a difficult process? Thank you! Charles
Jonathan Leung Jonathan Leung ⋅ Staff March 12, 2015
Response from Jonathan: Charles,
No, you really can’t add more games to the memory of your current Street Fighter 2 board but you can replace it with a multigame board that plays Street Fighter 2 along with several other games. Here are some multigame boards that are available from JAMMA Boards: http://www.jammaboards.com/store/multigame-pcbs-and-carts/. Keep in mind that while these boards should plug in to your cabinet and “work” (i.e. screen should come up, most of the buttons should work, etc.) you might have to rewire your harness/control panel in order to get all of the buttons working. Check out our post on Swapping Boards In A JAMMA Cabinet for more information. Hope that helps.
